Re: [cgal-discuss] exact precision, affine transformations, and newell's method
- To:
- Subject: Re: [cgal-discuss] exact precision, affine transformations, and newell's method
- Date: Tue, 02 Apr 2013 08:22:28 +0200
The problem comes from your transformation that is not exactly an affine one (you have a limited precision cosinus and sinus in your example).
Thus the points transformed no longer lie in a plane which implies that
the direction are not the same.
Sebastien.
On 03/29/2013 11:11 PM, Cody Rose wrote:
Hello,
I've stumbled into some CGAL behavior I can't explain and I was hoping
that someone could help me understand it. In my application, I'm using
Newell's method to calculate the approximate normal for a polygon-like
series of points (http://cs.haifa.ac.il/~gordon/plane.pdf). (The idea is
that if all the points are actually coplanar, it will yield the true
normal, but if they aren't quite, it will give a "best fit.") The
problem I'm having is essentially this, given a particular affine
transformation T and the kernel Cartesian<leda_real>:
newell(T(points)) != T(newell(points))
And I can't figure out why not, since I was under the impression that
this kernel is exact (and that this should work in an exact kernel). I
can't chalk it up to variations in how Newell's method approximates a
plane fit before and after the transformation, because in the example I
attached, all the points are actually coplanar after all. (Honestly that
explanation wouldn't make sense to me anyway.)
So I feel like I'm missing something about the way exactness (or this
affine transformation) works. Can anyone clear this up?
Cody Rose
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Sebastien Loriot (GeometryFactory), 04/02/2013
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Cody Rose, 04/02/2013
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Marc Mörig, 04/02/2013
- <Possible follow-up(s)>
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Marc Mörig, 04/04/2013
