Re: [cgal-discuss] exact precision, affine transformations, and newell's method
- To:
- Subject: Re: [cgal-discuss] exact precision, affine transformations, and newell's method
- Date: Tue, 02 Apr 2013 10:18:34 -0700
Thank you for your replies. I still do not understand your diagnoses of my problem exactly, but I think it might be helpful for me to take a step back to explain better what I'm doing.
The actual transformations in my application are defined by inexact tuples in the form (new x-axis, new y-axis, new z-axis, new origin). (I have no control over this - it is my input.) I have been generating each tuple into a CGAL Aff_transformation by first converting it to exact representation and then placing each normalized tuple member into the corresponding column of the Aff_transformation. (Obviously I don't normalize the new origin, and I understand that the sample code I provided skips the normalization step, but I just added it and the result is the same.)
Is this not an acceptable way to go about this? If not, how should I be doing it? And if so, I really feel the need to understand why the commutativity I'm looking for does not exist, so I'd appreciate some pointers towards further reading I can do (within the CGAL documentation or elsewhere) so I don't keep cluttering up this list with questions.
Thank you,
Cody
On 4/1/2013 11:58 PM, Marc Mörig wrote:
Now I was confused for a moment, since I had checked that the vectors do point in the same direction. However I had only printed the quotients not checked they are actually equal ...
Still, you explanation is incorrect. Regardless of what coefficients you write into the matrix, the transformation will preserve coplanarity. It does however not preserve angles or orthogonality. As you correctly pointed out, it can not be an exact rotation. That is why newell and T do not commute.
Marc
On 04/02/2013 08:22 AM, Sebastien Loriot (GeometryFactory) wrote:
The problem comes from your transformation that is not exactly an affine
one (you have a limited precision cosinus and sinus in your example).
Thus the points transformed no longer lie in a plane which implies that
the direction are not the same.
Sebastien.
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Sebastien Loriot (GeometryFactory), 04/02/2013
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Cody Rose, 04/02/2013
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Marc Mörig, 04/02/2013
- <Possible follow-up(s)>
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Marc Mörig, 04/04/2013
