cgal-discuss - Re: [cgal-discuss] exact precision, affine transformations, and newell's method
  • To:
  • Subject: Re: [cgal-discuss] exact precision, affine transformations, and newell's method
  • Date: Tue, 02 Apr 2013 10:09:30 +0200
Dear Sebastien,
as major part of my still ongoing PhD thesis I have implemented an exact number type, which I call RealAlgebraic, that supports + - . / and n-th roots. Like leda::real or CORE::Expr it stores arithmetic expressions in a dag, and, to compute their sign, evaluates them with increasing accuracy and decides that numbers are zero using separation bounds.
RealAlgebraic allows to exchange some of the major parts any such number type must have, you can for example use either leda::bigfloat or mpfr arithmetic as the workhorse behind the scenes. It furthermore employs exact computations with hardware floating-point numbers. These techniques require the default rounding mode to be set, but are entirely optional.
I have run a few experiments using algorithms from cgal (2D Delaunay Triangulation, homogeneous and Cartesian segment intersection, arrangements of circles, and Voronoi diagrams of segments) and can say that so far RealAlgebraic is a major improvement over leda::real and CORE::Expr. For arrangements of circles it comes close to what I call static algebraic predicates, i.e. predicates involving algebraic numbers of small degree based on static sturm sequences and similar techniques. For Voronoi diagrams of segments it clearly outperforms static algebraic predicates.
Of course there is the problem of selection bias in my experiments, that is why I would like to add at least one 'real world' application.
There is some code available at
http://wwwisg.cs.uni-magdeburg.de/ag/RealAlgebraic/
but it is over a year old. I intend to update that site soon, but need to add better installation support first. If you want to try RealAlgebraic yourself please ask me and I will provide you with a copy.
Marc
On 04/02/2013 07:21 AM, Sebastien Loriot (GeometryFactory) wrote:
What is "your number type"?
Sebastien.
Marc Mörig Email:
Institut für Simulation und Graphik Phone: +49 391 67-52858
Otto-von-Guericke Universität Magdeburg Office: G29-227
