- To:
- Subject: Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation
- Date: Mon, 6 May 2013 09:00:39 +0800
I have asked this question one week before but no get answered yet.
May I post the question here again?
The question is about to find the intersection (polyhedrons) of a cuboid or a cube and a tetrahedron.
I googled and found two most relevant threads discussing the polyhedron intersection.
and the other is http://www.gamedev.net/topic/621717-intersection-of-two-3d-polyhedrons/.
"The easiest way to calculate intersection of two polyhedrons is using of
class Nef_Polyhedron_3.
If You need to use some functions from Polyhedron_3 You can just convert
Polyhedron_3 into Nef_Polyhedron_3 (using constructor), calculate
intersection of polyhedrons and convert the resulting Nef_Polyhedron_3 into
Polyhedron_3 back (using function convert_to_polyhedron()).
Intersection is calculated with operation *
N1*N2
N1*N2
I have followed. The issue is: it works and coding is simple. The only issue is it is slow, and it is VERY slow in my case. I have billions of tetrahedrons to do the intersection test and operation.
My question is since this kind of intersection is sort of special: one is a cuboid and the other is a tetrahedron that is convex. How can I take advantage of those specific geometric features to speed up the intersection?
Thank you very much for your reading.
Your any hint will be highly appreciated.
Rong
2013/5/5 liudaisuda <>
Linking the dual points of two neighbor incident cells of a vertex is pretty much the same as getting the dual of the corresponding incident edge of that vertex. Do you have any idea why my approach didn't work ?On Sun, May 5, 2013 at 10:36 PM, 杨成林 [via cgal-discuss] <[hidden email]> wrote:
Why not just link the dual points of the incident cells?2013/5/5 liudaisuda <[hidden email]>
I test the code, and for each vertex, it only collected two segments of the
power cell. Therefore, it is clearly incorrect. Anyone has any suggestion
how to achieve my goal?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Dual-power-cell-of-a-vertex-in-Regular-Triangulation-tp4657357p4657358.html
杨成林
Yang Chenglin
http://cgal-discuss.949826.n4.nabble.com/Dual-power-cell-of-a-vertex-in-Regular-Triangulation-tp4657357p4657359.htmlIf you reply to this email, your message will be added to the discussion below:
View this message in context: Re: Dual power cell of a vertex in Regular Triangulation
- [cgal-discuss] Dual power cell of a vertex in Regular Triangulation, liudaisuda, 05/05/2013
- [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, liudaisuda, 05/05/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, 杨成林, 05/05/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, rong tian, 05/06/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, 杨成林, 05/06/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, Haibo Chen, 05/06/2013
- [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, liudaisuda, 05/06/2013
- Re: [cgal-discuss] Dual power cell of a vertex in Regular Triangulation, Sebastien Loriot (GeometryFactory), 05/06/2013
