- To:
- Subject: Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation
- Date: Mon, 6 May 2013 11:26:36 +0800
Never mind, a power cell is proved to be always convex. Looks like it might be because of the data in my power cell, The polygon_2 class also might have robustness problem. I'm gonna post another thread regarding to the problem
On Mon, May 6, 2013 at 10:42 AM, 杨成林 <> wrote:
If you do as what I suggested, you can store the computed dual points of cells, so they will not be computed again and again.--
2013/5/6 Haibo Chen <>
Sorry for the confusion, that was a typo. I am writing a relatively large program, so that was only a snapshot I made for demonstration purpose. I had a few mistakes there, the most serious one is I left out a ! before segment.is_degenate() which made the logic incorrect. It worked after that fix. I am trying toimplement what you suggested. By working counter-clockwise, I can get all segments of the power cell in the right order, because my eventual goal is to get the power cell polygon. Hopefully it will go well. Thanks for your suggestion.On Mon, May 6, 2013 at 9:21 AM, 杨成林 <> wrote:
I have not test your code, but I found some mistakes. Can this be compiled?
segments is std::vector<Point_2>. Segment can not be inserted into it.
RT::incident_edges and so on are not static functions, I don't think they can be used like this.
2013/5/5 liudaisuda <>Linking the dual points of two neighbor incident cells of a vertex is pretty much the same as getting the dual of the corresponding incident edge of that vertex. Do you have any idea why my approach didn't work ?On Sun, May 5, 2013 at 10:36 PM, 杨成林 [via cgal-discuss] <[hidden email]> wrote:
Why not just link the dual points of the incident cells?2013/5/5 liudaisuda <[hidden email]>
I test the code, and for each vertex, it only collected two segments of the
power cell. Therefore, it is clearly incorrect. Anyone has any suggestion
how to achieve my goal?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Dual-power-cell-of-a-vertex-in-Regular-Triangulation-tp4657357p4657358.html
杨成林
Yang Chenglin
http://cgal-discuss.949826.n4.nabble.com/Dual-power-cell-of-a-vertex-in-Regular-Triangulation-tp4657357p4657359.htmlIf you reply to this email, your message will be added to the discussion below:
View this message in context: Re: Dual power cell of a vertex in Regular Triangulation
杨成林
Yang Chenglin
杨成林
Yang Chenglin
- [cgal-discuss] Dual power cell of a vertex in Regular Triangulation, liudaisuda, 05/05/2013
- [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, liudaisuda, 05/05/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, 杨成林, 05/05/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, rong tian, 05/06/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, 杨成林, 05/06/2013
- Re: [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, Haibo Chen, 05/06/2013
- [cgal-discuss] Re: Dual power cell of a vertex in Regular Triangulation, liudaisuda, 05/06/2013
- Re: [cgal-discuss] Dual power cell of a vertex in Regular Triangulation, Sebastien Loriot (GeometryFactory), 05/06/2013
