cgal-discuss - Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features
  • To:
  • Subject: Re: [cgal-discuss] Re: 3D meshing of multidomain segmented images with sharp features
  • Date: Tue, 21 May 2013 10:39:38 -0700
Hi Andreas, Thanks for your response. I think perhaps that the part about
the sphere surface is not right but the interior subdomain_index seems to be
a real issue.
I'm setting the image data manually through function (a red flag I know, I
checked it many times and as far as I can tell it's working correctly). If I
can write this to an inr file I'll send it to you.
Dave
On May 21, 2013, at 3:02 AM, Andreas Fabri
wrote:
> Hi David,
> Is your post in the right thread? I can't see sharp features
> in your spheres.
> Can you provide the data set of the sphere, and the call
> to the mesh generator (plus the #includes and typedefs)
> so that we can try to reproduce and fix it.
> The same for a multidomain segmented image.
> best,
> andreas
> On 21/05/2013 03:40, David Bernstein wrote:
>> Here's an example of something I've been encountering. The image has
>> voxels
>> set to one value in the interior of a small sphere (the sphere is a few
>> dozen voxels in diameter) and another value outside. The mesh appears to
>> be
>> ok except many of the elements on the sphere surface and inside the sphere
>> have the subdomain index set to the wrong value. Oddly this happens in
>> some
>> cases (consistently in this one) and not others.
>> For instance, if I make the image smaller but with same size voxels and
>> same
>> size sphere, the mesh is fine. (This case has about 12 million voxels, the
>> small case where it works has about 1 million).
>> Dave
>> <http://cgal-discuss.949826.n4.nabble.com/file/n4657522/tmp1.png>
>> <http://cgal-discuss.949826.n4.nabble.com/file/n4657522/tmp2.png>
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/3D-meshing-of-multidomain-segmented-images-with-sharp-features-tp4657504p4657522.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912 skype: andreas.fabri
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
This e-mail contains privileged and confidential information intended for
the use of the addressees named above. If you are not the intended
recipient for this e-mail, you are hereby notified that you must not
disseminate, copy or take action in respect of any information contained in
it. If you have received this e-mail in error, please notify the sender
immediately by e-mail and destroy this e-mail and its attachments.
