- To:
- Subject: Re: [cgal-discuss] Re: Area of convex polygons with non-constant density
- Date: Mon, 27 May 2013 09:11:09 +0200
On 27/05/2013 08:59, liudaisuda wrote:
Thanks a lot for your suggestions. I have just done some research on your
second suggestion, and I figure it is not quite suitable in my case. Could
you please give me some references on how to discretize the polygon and
function? Honesty, I have no idea what you are talking about. Thanks again.
You could use the mesh generator
http://doc.cgal.org/4.2/CGAL.CGAL.2D-Conforming-Triangulations-and-Meshes/html/index.html#title4
and the size of the triangles could even be determined
by the function, for example you could say that a triangle
with corner points p,q, and r, is too big and must be split,
because f(p), f(q), and f(r) are too different.
andreas
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Area-of-convex-polygons-with-non-constant-density-tp4657579p4657584.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Area of convex polygons with non-constant density, liudaisuda, 05/26/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/26/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Andreas Fabri, 05/27/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, 杨成林, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Haibo Chen, 05/27/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/28/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/29/2013
