- To:
- Subject: Re: [cgal-discuss] Re: Area of convex polygons with non-constant density
- Date: Mon, 27 May 2013 16:18:50 +0200
Hello,
A good starting point might be the constrained triangulation demo.
In a subdirectory you can see a custom size criteria
CGAL-4.2/demo/Triangulation_2/include/CGAL/Lipschitz_sizing_field_criteria_2.h
You might just take it and adapt it to your needs.
andreas
On 27/05/2013 15:47, liudaisuda wrote:
Can you point out to me the CGAL class by which I can specify the meshing
criteria? The two available ones I found are Delaunay_mesh_criteria_2<CDT>.
Delaunay_mesh_size_criteria_2<CDT>. But I could find any way to impose the
custom criteria as you suggested.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Area-of-convex-polygons-with-non-constant-density-tp4657579p4657594.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Area of convex polygons with non-constant density, liudaisuda, 05/26/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/26/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Andreas Fabri, 05/27/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, 杨成林, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Haibo Chen, 05/27/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/28/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/29/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/29/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, 杨成林, 05/29/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Olivier Devillers, 05/29/2013
