cgal-discuss - [cgal-discuss] Re: Area of convex polygons with non-constant density
  • To:
  • Subject: [cgal-discuss] Re: Area of convex polygons with non-constant density
  • Date: Mon, 27 May 2013 07:22:56 -0700 (PDT)
Hi again,
Yang, what you propose is actually an other way to discretize the polygon :
small squares instead of small triangles. But you have to add a
normalization term in order to make your formula homogeneous. Look at the
previous formula:
[A] "value of the function at center of the triangle" x "area of the
triangle"
This has the dimension of an integral : function value x area. If you just
sum values of the function over the grid you propose, you'll only get a sum
of values. You have to multiply those values by the areas of each grid cell
to make up an integral value. A hint is that such areas should be small. The
formula becomes:
[B] "value of the function at center of the grid cell" x "area of the cell"
... And you just have to sum this result for all cells in your grid.
Best regards,
Hugo Loi
PhD student at Inria - Maverick team
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Area-of-convex-polygons-with-non-constant-density-tp4657579p4657598.html
