cgal-discuss - Re: [cgal-discuss] Re: Area of convex polygons with non-constant density
  • To:
  • Subject: Re: [cgal-discuss] Re: Area of convex polygons with non-constant density
  • Date: Mon, 27 May 2013 22:06:37 +0800
Here is another way. Maybe it is not so good.
Use a uniform grid to cover the polygon. Every grid point has its weight depending on the density. Then sum the weights of the grid points in the polygon.
2013/5/27 liudaisuda <>
Can you point out to me the CGAL class by which I can specify the meshing
criteria? The two available ones I found are  Delaunay_mesh_criteria_2<CDT>.
Delaunay_mesh_size_criteria_2<CDT>. But I could find any way to impose the
custom criteria as you suggested.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Area-of-convex-polygons-with-non-constant-density-tp4657579p4657594.html
杨成林
Yang Chenglin
