- To:
- Subject: Re: [cgal-discuss] Re: Area of convex polygons with non-constant density
- Date: Wed, 29 May 2013 12:52:43 +0200
Le 5/29/13 11:59 AM, liudaisuda a écrit :
what do you mean by density is linear. Sorry for this naive question.
instead of considering the density constant on a triangle (computed at the barycenter?)
you compute your value at the three vertices of the triangle and make a linear interpolation.
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, (continued)
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, 杨成林, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Haibo Chen, 05/27/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Andreas Fabri, 05/27/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/27/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/28/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/29/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, Tapadi, 05/29/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, 杨成林, 05/29/2013
- Re: [cgal-discuss] Re: Area of convex polygons with non-constant density, Olivier Devillers, 05/29/2013
- [cgal-discuss] Re: Area of convex polygons with non-constant density, liudaisuda, 05/31/2013
