- To:
- Subject: [cgal-discuss] Re: Extracting triangulation from alpha shape
- Date: Mon, 5 Aug 2013 08:46:57 -0700 (PDT)
That works in a quick test, thanks! Will submit the code when it's finished.
Best regards,
Ramon.
On 5 August 2013 16:14, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
On your side this time:
The class Fixed_alpha_shape_3 needs vertex and cell to be model of
FixedAlphaShapeVertex_3 and FixedAlphaShapeCell_3.
You can use CGAL::Fixed_alpha_shape_vertex_base_3<Gt> and
CGAL::Fixed_alpha_shape_cell_base_3<Gt>.
Sebastien.
On 08/05/2013 05:05 PM, rcasero wrote:> cgal-discuss] <[hidden email]
> On 5 August 2013 15:49, Sebastien Loriot (GeometryFactory) [via> *foo.txt* (55K) Download Attachment> </user/SendEmail.jtp?type=node&node=4657887&i=0>> wrote:>
> On 08/05/2013 04:33 PM, rcasero wrote:
> > (As a side note, I haven't noticed a speed improvement with the
> 400,000
> > point example).
> for the location or the insertion?
> For the CgalAlphaShape3.cpp function overall, which reads the list of
> points from Matlab, then builds the Delaunay triangulation, then the
> alpha shape, then extracts the triangulation for a particular alpha
> value (~48 sec on my machine all together).
> Checking the documentation, it seems that it'll be faster using
> a Fixed_alpha_shape_3 for a single value of alpha.
> I have modified the function adding
> typedef CGAL::Fixed_alpha_shape_3<Delaunay> Fixed_alpha_shape_3;
> Fixed_alpha_shape_3 as2(delaunay, 0.0);
> (I'm not doing anything to as2 so far, only trying to create the object).
> But there's a compilation error "has no member named ‘is_on_chull’". Is
> this a bug like before?
> Full error attached.
> Best regards,
> Ramon.
> Dr. Ramón Casero Cañas
> Oxford e-Research Centre (OeRC)
> University of Oxford
> 7 Keble Rd
> Oxford OX1 3QG
> tlf <a href=""tel:%2B44%20%280%29%201865%20610739"" value="+441865610739" target="_blank">+44 (0) 1865 610739
> web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas
> photos http://www.flickr.com/photos/rcasero/
> <http://cgal-discuss.949826.n4.nabble.com/attachment/4657887/0/foo.txt>>> <http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657887.html>
> View this message in context: Re: Extracting triangulation from alpha
> shape> Sent from the cgal-discuss mailing list archive
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657888.htmlIf you reply to this email, your message will be added to the discussion below:
7 Keble Rd
Oxford OX1 3QG
tlf +44 (0) 1865 610739
View this message in context: Re: Extracting triangulation from alpha shape
- [cgal-discuss] Extracting triangulation from alpha shape, rcasero, 08/01/2013
- Re: [cgal-discuss] Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/05/2013
- Re: [cgal-discuss] Re: Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/05/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/06/2013
