- To:
- Subject: [cgal-discuss] Re: Extracting triangulation from alpha shape
- Date: Tue, 6 Aug 2013 03:40:46 -0700 (PDT)
The MEX C++ code for CGAL alpha shapes and fixed alpha shapes is now available here
https://code.google.com/p/gerardus/source/browse/trunk/matlab/CgalToolbox/CgalAlphaShape3.cpp?r=1289
but it's slower than the Matlab implementation by Jonas Lundgren
I have done some profiling of the fixed alpha shape version, and it seems that although the alpha shape computation is fast, most of the time goes on computing the Delaunay triangulation. This is for a set of 412,068 points, for one value of alpha.
alphavol
11.469328 sec
cgal_fixed_alpha_shape3 with CGAL::Fast_location
49.118425 sec
cgal_fixed_alpha_shape3 without CGAL::Fast_location
46.946552 sec
The breakdown of the MEX C++ functions:
<PROFILING cgal_fixed_alpha_shape3 with CGAL::Fast_location>
Initializing and reading data from Matlab
time = 0.07 sec
Computing Delaunay triangulation
Delaunay triangulation computed
time = 43.15 sec
Computing alpha shape in REGULARIZED mode by default
Alpha shape computed in REGULARIZED mode by default
time = 2.98 sec
Extracting surface triangulation for alpha = 5.80644e-07
Number of facets = 22188
Surface triangulation extracted
time = 2.52 sec
</PROFILING>
<PROFILING cgal_fixed_alpha_shape3 without CGAL::Fast_location>
time = 0.07 sec
time = 41.1 sec
time = 2.88 sec
time = 2.51 sec
</PROFILING>
Best regards,
Ramon.
On 5 August 2013 16:46, Ramón Casero Cañas <[hidden email]> wrote:
That works in a quick test, thanks! Will submit the code when it's finished.Best regards,Ramon.On 5 August 2013 16:14, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
On your side this time:
The class Fixed_alpha_shape_3 needs vertex and cell to be model of
FixedAlphaShapeVertex_3 and FixedAlphaShapeCell_3.
You can use CGAL::Fixed_alpha_shape_vertex_base_3<Gt> and
CGAL::Fixed_alpha_shape_cell_base_3<Gt>.
Sebastien.
On 08/05/2013 05:05 PM, rcasero wrote:> cgal-discuss] <[hidden email]
> On 5 August 2013 15:49, Sebastien Loriot (GeometryFactory) [via> *foo.txt* (55K) Download Attachment> </user/SendEmail.jtp?type=node&node=4657887&i=0>> wrote:>
> On 08/05/2013 04:33 PM, rcasero wrote:
> > (As a side note, I haven't noticed a speed improvement with the
> 400,000
> > point example).
> for the location or the insertion?
> For the CgalAlphaShape3.cpp function overall, which reads the list of
> points from Matlab, then builds the Delaunay triangulation, then the
> alpha shape, then extracts the triangulation for a particular alpha
> value (~48 sec on my machine all together).
> Checking the documentation, it seems that it'll be faster using
> a Fixed_alpha_shape_3 for a single value of alpha.
> I have modified the function adding
> typedef CGAL::Fixed_alpha_shape_3<Delaunay> Fixed_alpha_shape_3;
> Fixed_alpha_shape_3 as2(delaunay, 0.0);
> (I'm not doing anything to as2 so far, only trying to create the object).
> But there's a compilation error "has no member named ‘is_on_chull’". Is
> this a bug like before?
> Full error attached.
> Best regards,
> Ramon.
> Dr. Ramón Casero Cañas
> Oxford e-Research Centre (OeRC)
> University of Oxford
> 7 Keble Rd
> Oxford OX1 3QG
> tlf <a href=""tel:%2B44%20%280%29%201865%20610739"" value="+441865610739" target="_blank">+44 (0) 1865 610739
> web http://www.cs.ox.ac.uk/people/Ramon.CaseroCanas
> photos http://www.flickr.com/photos/rcasero/
> <http://cgal-discuss.949826.n4.nabble.com/attachment/4657887/0/foo.txt>>> <http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657887.html>
> View this message in context: Re: Extracting triangulation from alpha
> shape> Sent from the cgal-discuss mailing list archive
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
http://cgal-discuss.949826.n4.nabble.com/Extracting-triangulation-from-alpha-shape-tp4657870p4657888.htmlIf you reply to this email, your message will be added to the discussion below:--
7 Keble Rd
Oxford OX1 3QG
7 Keble Rd
Oxford OX1 3QG
tlf +44 (0) 1865 610739
View this message in context: Re: Extracting triangulation from alpha shape
- [cgal-discuss] Extracting triangulation from alpha shape, rcasero, 08/01/2013
- Re: [cgal-discuss] Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/02/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/05/2013
- Re: [cgal-discuss] Re: Extracting triangulation from alpha shape, Sebastien Loriot (GeometryFactory), 08/05/2013
- [cgal-discuss] Re: Extracting triangulation from alpha shape, rcasero, 08/06/2013
