- To:
- Subject: Re: [cgal-discuss] surface point insertion
- Date: Tue, 03 Sep 2013 17:42:11 +0200
Le mardi 03 septembre 2013 15:37:17
a écrit :
> Is there any example for inserting surface points (with connectivity) into a
> volumetric mesh?
Please be more explicit. What do you call a volumetric mesh? The 'c3t3'
created by the CGAL 3D mesh generator?
What you want is probably quite difficult to implement without knowing a lot
of the internal of the CGAL 3D mesh generator.
Laurent Rineau, PhD
- [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Laurent Rineau (CGAL/GeometryFactory), 09/03/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Mariette Yvinec, 09/05/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/05/2013
