- To:
- Subject: Re: [cgal-discuss] surface point insertion
- Date: Thu, 05 Sep 2013 12:11:07 +0200
Hi Kamal I am not sure to understand your problem but still I make an attempt of solution : you may insert whatever points you want (surface points in particular) in the triangulation, using c3t3.triangulatiun().insert() before launching the meshing process. These points will be preserved in the final mesh if you next build the mesh using refine_mesh() Hi Laurent, I am looking for an example using the following function, But before I want to know if this preserves the surface connectivity as well? c3t3.insert_surface_points(...)) I tried also to add a contour (as a feature) from the respective surface using: domain.add_features(polylines.begin(), polylines.end()); this works perfectly but when I added all edges from the surface, I was not successful. -----Original Message----- From: [mailto:] On Behalf Of Laurent Rineau (CGAL/GeometryFactory) Sent: Tuesday, September 03, 2013 5:42 PM To: Subject: Re: [cgal-discuss] surface point insertion Le mardi 03 septembre 2013 15:37:17 a écrit : Is there any example for inserting surface points (with connectivity) into a volumetric mesh? Please be more explicit. What do you call a volumetric mesh? The 'c3t3' created by the CGAL 3D mesh generator? What you want is probably quite difficult to implement without knowing a lot of the internal of the CGAL 3D mesh generator. -- Laurent Rineau, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Release Manager of the CGAL Project http://www.cgal.org/ -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Laurent Rineau (CGAL/GeometryFactory), 09/03/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Mariette Yvinec, 09/05/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/05/2013
