- To: <>
- Subject: RE: [cgal-discuss] surface point insertion
- Date: Tue, 3 Sep 2013 15:54:58 +0000
- Accept-language: fr-CH, de-CH, en-US
Hi Laurent,
I am looking for an example using the following function,
But before I want to know if this preserves the surface connectivity as well?
c3t3.insert_surface_points(...))
I tried also to add a contour (as a feature) from the respective surface
using:
domain.add_features(polylines.begin(), polylines.end());
this works perfectly but when I added all edges from the surface, I was not
successful.
-----Original Message-----
[mailto:]
On Behalf Of Laurent Rineau (CGAL/GeometryFactory)
Sent: Tuesday, September 03, 2013 5:42 PM
To:
Subject: Re: [cgal-discuss] surface point insertion
Le mardi 03 septembre 2013 15:37:17
a écrit :
> Is there any example for inserting surface points (with connectivity)
> into a volumetric mesh?
Please be more explicit. What do you call a volumetric mesh? The 'c3t3'
created by the CGAL 3D mesh generator?
What you want is probably quite difficult to implement without knowing a lot
of the internal of the CGAL 3D mesh generator.
Laurent Rineau, PhD
- [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Laurent Rineau (CGAL/GeometryFactory), 09/03/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/03/2013
- Re: [cgal-discuss] surface point insertion, Mariette Yvinec, 09/05/2013
- RE: [cgal-discuss] surface point insertion, kamal.shahim, 09/05/2013
