- To:
- Subject: [cgal-discuss] Memory leak in snap_rounding_2?
- Date: Mon, 21 Oct 2013 18:33:28 -0700 (PDT)
First of all, please note that I am in the first place developing in C#, and
only just started maintenance work on a native C++ library which uses CGAL.
So please bear with me if I'm missing something obvious.
The problem I believe to have located is the /Multiple_kd_tree *
mul_kd_tree/ in the snap_rounding_2 constructor. This tree gets created in
/s.find_hot_pixels_and_create_kd_trees/, is used by /s.iterate/, but
immediately after that the constructor ends. This means that the
Multiple_kd_tree, nor any of its children, get freed.
I would appreciate it if someone with more C++ experience than me could take
a look at this, to confirm if I managed to locate the issue correctly. Also,
if possible, please advise on how i can correct this problem.
Thank you,
Steven
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Memory-leak-in-snap-rounding-2-tp4658264.html
- [cgal-discuss] Memory leak in snap_rounding_2?, Steven, 10/22/2013
- Re: [cgal-discuss] Memory leak in snap_rounding_2?, Philipp Moeller, 10/22/2013
- Re: [cgal-discuss] Memory leak in snap_rounding_2?, Steven, 10/25/2013
- Re: [cgal-discuss] Memory leak in snap_rounding_2?, Philipp Moeller, 10/30/2013
