cgal-discuss - [cgal-discuss] About .locate function
  • To:
  • Subject: [cgal-discuss] About .locate function
  • Date: Mon, 21 Oct 2013 18:14:17 -0700 (PDT)
Hello, I am a newer to CGAL, and when I use the .locate() function to locate
a point in a triangle, there is some problem.
First I build a triangle with three point (-1,0) (1,0) (0,1),
Then I check some points' relative location with the triangle,
the points are:
p0(0.8, 0.1) ---- locate in the triangle
p1(0.95, 0) ---- locate on the edge (-1,0) ---- (1,0)
p2(0.8, 0.2) ---- locate on the edge (1,0) ---- (0,1)
p3(0.6, 0.4) ---- locate on the edge (1,0) ---- (0,1)
p4(0.7,0.3) ---- locate on the edge (1,0) ---- (0,1)
But the locate results are:
p0 ---- FACE, right!
p1 ---- EDGE, right!
p2 ---- OUTSIDE_CONVEX_HULL, wrong!
p3 ---- EDGE, right!
p4 ---- FACE, wrong!
while the points p2, p3, p4 are locating on the same edge (1,0) ---- (0,1)
What's the problem?
The code:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_2<K> Delaunay_triangulation;
void main()
//generate the triangles
std::vector<Point2> pts;
pts.push_back(Point2(1,0));
pts.push_back(Point2(-1,0));
pts.push_back(Point2(0,1));
Delaunay_triangulation dt;
dt.insert(pts.begin(), pts.end());
//locate point in the triangle
Point2 pt0 = Point2(0.8, 0.1);//the point located in the triangle.(on the
FACE ?)
Point2 pt1 = Point2(0.95, 0);//the point located on the segment ( (1,0) ----
(-1,0) ) (on the EDGE ?)
Point2 pt2 = Point2(0.8, 0.2);//the point locate on the segment ( (1,0) ----
(0,1) ) (on the EDGE ?)
Point2 pt3 = Point2(0.6, 0.4);//the point locate on the segment ( (1,0) ----
Point2 pt4 = Point2(0.7,0.3);//the point locate on the segment ( (1,0) ----
Face_handle fh0, fh1, fh2, fh3, fh4;
Delaunay_triangulation::Locate_type lt0, lt1, lt2, lt3, lt4;
int li;
fh0 = dt.locate(pt0, lt0, li);//for pt0, lt0 is equal to FACE, right!
fh1 = dt.locate(pt1, lt1, li);//for pt1, lt1 is equal to EDGE, right!
fh2 = dt.locate(pt2, lt2, li);//for pt2, lt2 is equal to
OUTSIDE_CONVEX_HULL, I think it's wrong!
fh3 = dt.locate(pt3, lt3, li);//for pt3, lt3 is equal to EDGE, right!
fh4 = dt.locate(pt4, lt4, li);//for pt4, lt3 is equal to FACE, I thing it's
wrong!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/About-locate-function-tp4658262.html
