- To:
- Subject: Re: [cgal-discuss] Mesh simplification with edges marked as non-removable
- Date: Tue, 22 Oct 2013 07:41:04 +0200
Providing me only results without any code showing how they were
produced is not that helpful.
Please provide a minimal compilable example showing the problem.
Thanks,
Sebastien.
On 10/18/2013 12:29 AM, costantinos wrote:
Hi Sebastien,
My aim is to find the most representative coarse triangulation on a 3-d
surface possible. I want to constrain the border edges on a surface or the
sharp feature edges on closed geometry (by calculating the angle between the
normals on either side of a half-edge and marking them) to ensure that they
remain in their fixed position.
However, from the examples attached you can see I am not getting improved
results from constraining the edges! So my question is how does the
constraint work and what are the limitations?
Thanks.
simplification_examples.zip
<http://cgal-discuss.949826.n4.nabble.com/file/n4658241/simplification_examples.zip>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-simplification-with-edges-marked-as-non-removable-tp4658180p4658241.html
- [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/11/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/14/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/18/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, 柳米, 10/25/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/25/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/25/2013
