- To:
- Subject: Re: [cgal-discuss] About .locate function
- Date: Mon, 28 Oct 2013 13:19:00 +0100
Le 10/22/13 10:13 AM, ffmm3 a écrit :
If I want determine the relative position between the point(0.7,0.3) and the triangle with vertices(-1,0)(1,0)(0,1) precisely, what should I do? A said, you can use a fully exact kernel. A cheaper solution is to use the Inexact constructions exact predicates kernel with a number type that can represent your input. e.g. if instead of point(0.7,0.3) and the triangle with vertices(-1,0)(1,0)(0,1)you have point(7,3) and the triangle with vertices(-10,0)(10,0)(0,10)everything will work perfectly. --
Olivier Devillers, chercheur à |
- [cgal-discuss] About .locate function, ffmm3, 10/22/2013
- Re: [cgal-discuss] About .locate function, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] About .locate function, ffmm3, 10/26/2013
- Re: [cgal-discuss] About .locate function, Laurent Rineau (CGAL/GeometryFactory), 10/28/2013
- Re: [cgal-discuss] About .locate function, Sebastien Loriot (GeometryFactory), 10/28/2013
- Re: [cgal-discuss] About .locate function, Olivier Devillers, 10/28/2013
