- To:
- Subject: Re: [cgal-discuss] Mesh simplification with edges marked as non-removable
- Date: Fri, 25 Oct 2013 07:29:10 -0700 (PDT)
That is very interesting, but I don't know how to set the edge cost to double
positive infinity. I would be very grateful for any help you can give me!
I did check the implications of the precision by setting:
typedef CGAL::Simple_cartesian<double> Kernel;
to
typedef CGAL::Simple_cartesian<long double> Kernel;
and the simplification behaved much better.
Thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-simplification-with-edges-marked-as-non-removable-tp4658180p4658295.html
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, (continued)
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/14/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/18/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, 柳米, 10/25/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/25/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/25/2013
