- To:
- Subject: Re: [cgal-discuss] Mesh simplification with edges marked as non-removable
- Date: Thu, 24 Oct 2013 19:39:29 +0200
I can finally reproduce the problem you observed.
I'll investigate and let you know.
Thanks,
Sebastien.
On 10/24/2013 05:32 PM, costantinos wrote:
Here is a .xyz file if you visualise it (I use Meshlab), you will see that I
am treating the surface boundary edges as the borders! Maybe I cannot treat
them as such, maybe that is where my mistake is? I just want to ensure the
that the topology and volume are preserved on the model following the
simplification process.
tens_boundary.xyz
<http://cgal-discuss.949826.n4.nabble.com/file/n4658281/tens_boundary.xyz>
I have been running my code at command line as follows (I have not been
using cmake):
g++ 3d_decimation.cpp -o test -L/opt/local/lib -I/opt/local/include -lCGAL
-lgmp -lmpfr -lboost_thread-mt -frounding-math -lboost_system-mt
and then,
./test tens.off results.off
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-simplification-with-edges-marked-as-non-removable-tp4658180p4658281.html
- [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/11/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/14/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/18/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/22/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/24/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, 柳米, 10/25/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, costantinos, 10/25/2013
- Re: [cgal-discuss] Mesh simplification with edges marked as non-removable, Sebastien Loriot (GeometryFactory), 10/25/2013
