cgal-discuss - Re: [cgal-discuss] Mesh simplification with edges marked as non-removable
  • To:
  • Subject: Re: [cgal-discuss] Mesh simplification with edges marked as non-removable
  • Date: Thu, 24 Oct 2013 16:57:11 +0200
There is no border in tens, so I still don't understand sorry.
Could you please provide a main.cpp so that I just need to do
cmake .; make; ./main tens.off to see the problem?
Thanks,
Sebastien.
On 10/24/2013 04:20 PM, costantinos wrote:
Sorry.
The face-YO.off and tens.off are the baseline models used in the
simplification.
The face-YO_wo_constraint_0.2.off and the tens_wo_const_0.0185.off are
results of the above mentioned models run *without* (wo) any constraint
using code straight from the website. They show the best results!
The tens_w_const_0.2.off and tens_w_const_0.12.off result from the code in
3d_decimation.cpp which constrains the border edges and has stop ratios of
0.2 and 0.12, respectively.
The face-YO_w_const_0.2.off and face-YO_w_const_0.4.off result from the code
in 3d_surface_decimation.cpp which constrains the border edges and has stop
ratios of 0.2 and 0.4 respectively.
My question is why does constraining the border edges not fix the borders in
space and leads to errors especially in the closed geometry like in
tens_w_const_0.12.off? Am I defining the constraints incorrectly?
Thank you for your patience.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-simplification-with-edges-marked-as-non-removable-tp4658180p4658278.html
