cgal-discuss - Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization"
  • To:
  • Subject: Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization"
  • Date: Fri, 25 Oct 2013 16:48:22 +0200
On 10/25/2013 04:44 PM, Burak ER wrote:
Hi Sebastien,
I am now having difficulties with the space filling tetrahedrons. They
are too small[1] when compared to other tetrahedrons. How can I prevent
this behavior?
Sorry for these newbie questions.
I guess it's coming from the way you protected the sharp edges. You need to reduce the number of protecting balls on the sharp edges.
Sebastien.
Thank you.
Burak
[1]http://s10.postimg.org/rblr196hl/Screenshot_from_2013_10_25_17_40_10.png
Cum, 2013-10-25 tarihinde 16:13 +0300 saatinde, Burak ER yazdı:
Thank you,
This solved my problem.
Burak ER
Cum, 2013-10-25 tarihinde 12:03 +0200 saatinde, Sebastien Loriot
(GeometryFactory) yazdı:
You need to protect the edges of your box.
One solution is to do like this example:
http://doc.cgal.org/latest/Mesh_3/index.html#Mesh_3MeshingDomainswithSharpFeatures
or to protect them by hand.
Sebastien.
On 10/25/2013 11:20 AM, Burak ER wrote:
Sorry for the not working link. You can find it here.
<http://s16.postimg.org/pv4ehn3et/Screenshot_from_2013_10_25_12_17_21.png>
Cum, 2013-10-25 tarihinde 12:14 +0300 saatinde, Burak ER yazdı:
Dear Sebastian,
This may not be a minimal example. I have created a python interface
for my application. Within this interface I divide the off file into
tetrahedrons with CGAL c++ api on the background. I use this
generation code on the c++ side;
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Polyhedral_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/refine_mesh_3.h>
#include <iostream>
// IO
#include <CGAL/IO/Polyhedron_iostream.h>
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Polyhedron_3<K> Polyhedron;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, K> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
class MeshElement;
void Mesh(void)
boost::filesystem::path mypath(filename);
std::ifstream input(filename.data());
if(mypath.extension()!=boost::filesystem::path(".off")){
std::string errormessage ="Invalid extension is specified with the
mesh file";
throw std::invalid_argument(errormessage);
// Create input polyhedron
Polyhedron polyhedron;
input >> polyhedron;
// Create domain
Mesh_domain domain(polyhedron);
// Mesh criteria (no cell_size set)
Mesh_criteria criteria(facet_angle, facet_size,
facet_distance,/*facet_topology*/
cell_radius_edge_ratio, cell_size);
// Mesh generation
c3t3.clear();
c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, no_perturb(),
no_exude());
elems.clear();// clear our vector
interfacingpairs.clear();
handlemap.clear();
elems.resize(c3t3.number_of_cells_in_complex()); // resize it as the
new number of elements
size_t i=0;
* This is not a nice way to index elements
* we could use cell_with_info structure of cgal but really how to
use that? No tutorial, no example at all on its document!!!
for(C3t3::Cells_in_complex_iterator
it=c3t3.cells_begin();it!=c3t3.cells_end();it++){
//Create new elements
//share_ptr handles deletion of the newly created element
elems[i]=shared_ptr<MeshElement>(new Linear4NodeTetMeshElem(it));
//Give an index to handle
handlemap[it]=i;
i++;
// Add interactions
//For each neighbor of the currrent iterator
for(int j=0;j<4;j++)
C3t3::Cell_handle neigh=it->neighbor(j);
/*Check if we have this neighbor handle*/
if(c3t3.is_in_complex(neigh))
size_t indexel=handlemap[it];
size_t indexneigh=handlemap[neigh];
//Get element and its neighbors from element list
shared_ptr<MeshElement> el;
shared_ptr<MeshElement> neighel;
//Change the ordering of the elements
if(indexel<indexneigh){
el=elems[indexel];
neighel=elems[indexneigh];}
else{
neighel=elems[indexel];
nodePairsIndices indiceofpairs;
//Get shared node list
indiceofpairs=getNodeCon(el,neighel);
//check if there is a face share
if(indiceofpairs.size()>=3)
//Create the pair
ElementPair pair(el,neighel,indiceofpairs);
//Add it into the interfacing pair list
if(!interfacingpairs[pair])
interfacingpairs[pair]=shared_ptr<ElementPair>(new
ElementPair(el,neighel,indiceofpairs));
std::cout<<"Meshing is complete "<<std::endl;
std::cout<<"Number of tetrahedral elements "<<elems.size()<<std::endl;
std::cout<<"Number of interaction elements
"<<interfacingpairs.size()<<std::endl;
Using this function and the off file in the attachment;
When I use the parameters as
facet_angle=33,
facet_distance=.6,
facet_size=0.6,
cell_radius_edge_ratio=0.11,
cell_size=1e-3
The result is 5580 elements and they are distributed as here <http://>
where you can see the empty parts on the boundary of the plate.
Also slight change on the cell_radius_edge_ratio=0.15 makes it even
worser as here.
<http://s14.postimg.org/o8j6yl07l/Screenshot_from_2013_10_25_12_08_06.png>
What do you think the problem is?
Burak
Cum, 2013-10-25 tarihinde 09:28 +0200 saatinde, Sebastien Loriot
It might help if you share a minimal example showing the pb.
Sebastien.
On 10/25/2013 09:26 AM, Burak ER wrote:
Dear Cgal Users,
I really need help on this problem. Still waiting for an answer.
Thank you in advance.
Burak ER
Pzt, 2013-10-21 tarihinde 18:40 +0300 saatinde, Burak ER yazdı:
Dear Cgal Users,
I am trying to mesh a rectengular prism domain from an off file into
tetrahedral elements using cgal. But whatever parameters I use within
criteria structure, I get a mesh where the boundaries are not conserved
rather they are "uneven".
What may cause that? How to force keeping boundaries exact while
meshing?
Burak ER
Research Assistant
Mechanical Engineering Department
Bursa Technical University
Burak ER
<mailto:>>
Bu elektronik posta ve ekleri sadece adreste belirtilen kisi veya
kurulusun kullanimi icin gonderilmektedir. Bu mesaj tarafiniza
yanlislikla ulasirsa, lutfen gonderen kisiyi bilgilendiriniz ve mesaji
sisteminizden siliniz. Mesajda ve eklerinde yer alan bilgilerin her ne
sekilde olursa olsun ucuncu kisiler ile paylasilmasi hukuki ve cezai
sorumluluk dogurabilir. Bursa Teknik Universitesi'nin, bu mesaj ve
eklerinin icerigi ve yayimi ile ilgili hicbir sorumlulugu bulunmamaktadir.
This email and the attachments are sent to the individual or entity
defined in the address field only. If you are not the intended
recipient or have received the message in error, please notify the
sender and remove the message from your system immediately. Sharing the
information in the message or the attachments with the 3rd parties may
cause legal rules and penalties to apply. Bursa Technical University has
no responsibility on the submission of this message and the attachments.
Burak ER
