cgal-discuss - Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization"
  • To:
  • Subject: Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization"
  • Date: Mon, 28 Oct 2013 10:33:40 +0100
Le samedi 26 octobre 2013 23:18:53 Burak ER a écrit :
> Hi,
> Would you please guide me to achieve a meshing procedure where I only
> set the minimum element volume. Therefore, I have the ability to change
> the mesh density with having it uniform with using a single parameter.
> Is it possible? Can you provide me a simple example of code?
The simple example of code is the one Sébastien already showed you in the manual:
http://doc.cgal.org/latest/Mesh_3/index.html#Mesh_3MeshingDomainswithSharpFeatures
You need to tweak the criteria. Try this way of choosing the criteria:
double my_size; // set the size you want
Mesh_criteria criteria(edge_size = my_size,
facet_angle = 25,
facet_size = my_size,
facet_distance = my_size/10,
cell_radius_edge_ratio = 3,
cell_size = my_size);
Laurent Rineau, PhD
