Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles
- To:
- Subject: Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles
- Date: Tue, 19 Nov 2013 22:12:46 +0100
On 11/19/2013 03:00 PM, KeithSloan52 wrote:
Can anybody point me to an efficient algorithm ( not necessarily CGAL ) thatCould you give an example? it is not clear to me what you want to do.
can calculate a four sided polygons to replace two mesh triangles that are
in the same or very similar plane.
Thanks
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Efficient-algorithm-for-calculating-a-four-sided-polygon-to-replace-two-mesh-triangles-tp4658431.html
- [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, KeithSloan52, 11/19/2013
- Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, Sebastien Loriot (GeometryFactory), 11/19/2013
- Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, KeithSloan52, 11/20/2013
- Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, Guillaume Damiand, 11/20/2013
