Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles
- To:
- Subject: Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles
- Date: Wed, 20 Nov 2013 10:08:51 +0100
Le 20/11/2013 09:41, KeithSloan52 a écrit :
Well I will try.
If I have a mesh any time I have two triangles that share the same edge and
are in the same plane or close to, I would like to remove the shared edge so
that I am left with a poylgon. ABCD in diagram
<http://cgal-discuss.949826.n4.nabble.com/file/n4658438/diag.png>
The principle of the algorithm:
Iterate through all the edges of the mesh, test if the two triangles incident to the edge are in the same plane or close to, and when it is the case call the join_facet method
cf http://doc.cgal.org/latest/Polyhedron/classCGAL_1_1Polyhedron__3.html#a4f3e7c4e0800462026443a7ad0ca6db8
to merge the two triangles around a given edge.
Guillaume
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Efficient-algorithm-for-calculating-a-four-sided-polygon-to-replace-two-mesh-triangles-tp4658431p4658438.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, KeithSloan52, 11/19/2013
- Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, Sebastien Loriot (GeometryFactory), 11/19/2013
- Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, KeithSloan52, 11/20/2013
- Re: [cgal-discuss] Efficient algorithm for calculating a four sided polygon to replace two mesh triangles, Guillaume Damiand, 11/20/2013
