- To: Philipp Moeller <>
- Cc:
- Subject: Re: [cgal-discuss] lower_hull_2() problem
- Date: Fri, 17 Jan 2014 23:32:15 +0100
Thanks Philipp, I'm going to use the library as suggested by you :)
On 16 January 2014 23:23, Philipp Moeller <> wrote:
Alessandro Attanasi <> writes:This has the *appearance* of working. The code causes undefined behavior
> Hi Philipp,
> I understood the behaviour with the STL, I was wondering about C way usage
> of CGAL as the following , that is working fine even if I used malloc() and
> free() while for the function lower_hull_points_2() a similar approach
> doesn't work at all, I was expecting the same behaviour but I missing
> something.
for reasons I pointed out before. I also don't understand what you mean
by "C way usage". CGAL is a C++ library. There is no straight-forward
way to use it from C.
Philipp Moeller
> // definition of the input points
> K::Point_2 p1(2,5);
> K::Point_2 p2(0,4);
> K::Point_2 p3(0,0);
> K::Point_2 p4(4,0);
> K::Point_2 p5(4,4);
> K::Point_2 p6(1,3);
> K::Point_2 p7(1,1);
> K::Point_2 p8(3,1);
> K::Point_2 p9(3,3);
> K::Point_2 p10(2,2);
> int totPoints = 10;
> // array storing input points
> K::Point_2 *points = NULL;
> points = (K::Point_2*)malloc(totPoints * sizeof(K::Point_2));
> points[0] = p1;
> points[1] = p2;
> points[2] = p3;
> points[3] = p4;
> points[4] = p5;
> points[5] = p6;
> points[6] = p7;
> points[7] = p8;
> points[8] = p9;
> points[9] = p10;
> // array storing results
> K::Point_2 *result = NULL;
> result = (K::Point_2*)malloc(totPoints * sizeof(K::Point_2));
> ptr = CGAL::ch_akl_toussaint( points, points+totPoints, result );
> // see how many points are into the convex hull
> int ch_points = (ptr - result);
> // print out the number of points of the convex hull and the points
> themselves
> std::cout << "1) Points on the convex hull = " << ch_points << std::endl;
> for(int i =0;i<ch_points;i++)
> std::cout << result[i] << std::endl;
> free(points);
> points = NULL;
> free(result);
> result = NULL;
> On 15 January 2014 23:58, Philipp Moeller <
>> > Ok, but why that procedure was working using all convex_hull
>> > functions?
>> It was working because you were using std::vector with a back_inserter
>> which takes care of those things. At least this is what your code
>> did. There can be situations where using a malloc'd pointer as an
>> OutputIterator can work (with a POD-type assignment effectively becomes
>> a memcpy, IIRC this is still undefined behavior though).
>> > I started from the cgal example
>> http://doc.cgal.org/latest/Convex_hull_2/Convex_hull_2_2array_convex_hull_2_8cpp-example.html
>> > I freed the malloc at the end :)
>> Which is exactly the wrong thing to do because it won't call the
>> destructors of the elements.
>> > On 15 January 2014 23:31, Philipp Moeller <
>> >> > Sorry, really stupid error :P. It works as expected!
>> >> > Just last question about this problem: if I want to use C pointers
>> >> instead
>> >> > of stl iterators, why this code is wrong? It gives to me zero points
>> on
>> >> the
>> >> > lower hull (I tried to use the same logic of the example for convex
>> hull
>> >> > computation)
>> >> > K::Point_2 *ptr2;
>> >> > K::Point_2 *result2 = NULL;
>> >> > result2 = (K::Point_2*)malloc(totPoints * sizeof(K::Point_2));
>> >> > ptr2 = CGAL::lower_hull_points_2( points, points+totPoints, result2
>> >> Why would you ever call malloc instead of new in such a situation? It is
>> >> exactly where your problem comes from. You cannot simply use raw
>> >> uninitialized memory as an OutputIterator. You should wrap the pointer
>> >> into a raw_storage_iterator provided by the standard header memory. [1]
>> >> You also need to take special care when releasing the memory (call the
>> >> destructor explicitly).
>> >> > ch_points = (ptr2 - result2);
>> >> > std::cout << "6) Points on the lower hull = " << ch_points <<
>> >> std::endl;
>> >> > std::cout << result2[i] << std::endl;
>> >> Footnotes:
>> >> [1] http://en.cppreference.com/w/cpp/memory/raw_storage_iterator
GeometryFactory
- [cgal-discuss] lower_hull_2() problem, Alessandro Attanasi, 01/14/2014
- Re: [cgal-discuss] lower_hull_2() problem, Philipp Moeller, 01/15/2014
- Re: [cgal-discuss] lower_hull_2() problem, Alessandro Attanasi, 01/15/2014
- Re: [cgal-discuss] lower_hull_2() problem, Philipp Moeller, 01/16/2014
- Re: [cgal-discuss] lower_hull_2() problem, Alessandro Attanasi, 01/16/2014
- Re: [cgal-discuss] lower_hull_2() problem, Alessandro Attanasi, 01/17/2014
