- To:
- Subject: [cgal-discuss] graham_andrew_scan() problem
- Date: Sat, 18 Jan 2014 23:25:42 +0100
Hi,
I'm not understanding the behaviour of the graham_andrew_scan()
what should I expect if I have the following points?
q7
q4
q1 q2 q3
q5
q6
q1 (-1,0)
q2 (0,0)
q3 (1,0)
q4 (2,1)
q5 (2,-1)
q6 (1.5,-2)
q7 (1.5,2)
I filled a std::vector<Point_2> scan_test with this points in the order given by the numbers above, then I called
CGAL::graham_andrew_scan(scan_test.begin(),scan_test.end(),std::back_inserter(scan_result));
being std::vector<Point_2> scan_result.
And as result I obtained
q1,q3,q4 into scan_result. Why?
Thanks
Alessandro
- [cgal-discuss] graham_andrew_scan() problem, Alessandro Attanasi, 01/18/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Panagiotis Cheilaris, 01/19/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Andreas Fabri, 01/19/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Alessandro Attanasi, 01/19/2014
