- To:
- Subject: Re: [cgal-discuss] graham_andrew_scan() problem
- Date: Sun, 19 Jan 2014 12:01:45 +0200
On Sat 2014-01-18 at 23:25:42 +0100, Alessandro Attanasi wrote:
> Hi,
> I'm not understanding the behaviour of the graham_andrew_scan()
> what should I expect if I have the following points?
> q7
> q4
> q1 q2 q3
> q5
> q6
> q1 (-1,0)
> q2 (0,0)
> q3 (1,0)
> q4 (2,1)
> q5 (2,-1)
> q6 (1.5,-2)
> q7 (1.5,2)
> I filled a std::vector<Point_2> scan_test with this points in the order
> given by the numbers above, then I called
> CGAL::graham_andrew_scan(scan_test.begin(),scan_test.end(),std::back_inserter(scan_result));
Hi Alessandro,
First of all, I think there is no graham_andrew_scan but only
ch_graham_andrew_scan. Please check this. As a general remark,
whenever you have a problem, you could send a minimal example
of code that compiles and when run gives your claimed output.
> being std::vector<Point_2> scan_result.
> And as result I obtained
> q1,q3,q4 into scan_result. Why?
I think ch_graham_andrew_scan requires the input vector of
points to be somehow sorted and your input is not.
I think you should sort the points with Less_xy_2.
What did you expect to get?
Best,
Panos
- [cgal-discuss] graham_andrew_scan() problem, Alessandro Attanasi, 01/18/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Panagiotis Cheilaris, 01/19/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Andreas Fabri, 01/19/2014
- Re: [cgal-discuss] graham_andrew_scan() problem, Alessandro Attanasi, 01/19/2014
