- To:
- Subject: [cgal-discuss] Simplification: selection process and constrained edges
- Date: Thu, 3 Apr 2014 09:00:59 -0700 (PDT)
I'm not clear about the edge to be collapsed selection process. I'll try to
understand it from the code, but I think that the documentation can be
clearer about this. I have two types of constraints on edges:
1. A constraint that isn't going to change, and this edge would never be
collapsed.
2. A temporary constraint that is relevant to the current mesh state, and
might change (be lifted/removed) later, when the mesh changes.
I put both types in EdgeConstraints::is_constrained(), but clearly it's a
mistake. For example, in Edge_collapse_visitor_base::OnCollected() it seems
that constrained edges (even temporary) would never be checked again. So I'm
guessing that temporary constraints should be added to
Edge_collapse_visitor_base::OnSelected() or MyPlacement::operator().
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplification-selection-process-and-constrained-edges-tp4659059.html
- [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Sebastien Loriot (GeometryFactory), 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/12/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/13/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Sebastien Loriot (GeometryFactory), 04/14/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/14/2014
