- To:
- Subject: Re: [cgal-discuss] Simplification: selection process and constrained edges
- Date: Thu, 03 Apr 2014 19:46:21 +0200
On 04/03/2014 07:39 PM, Zohar wrote:
I'm doing simplification of a mesh with parametrization, style:
(Bommes13) "Integer-Grid Maps for Reliable Quad Meshing"
The simplification is done in domain (R^2) as well as the surface (R^3). I
start with a bijective parametrization, and I want to keep it this way. So,
if an edge which is about to collapse is going to violate bijectivity, I'd
like it not be collapsed at this state of the mesh.
I think you better use the placement in that case. IIRC, if no placement
can be computed the edge will not be collapsed.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Simplification-selection-process-and-constrained-edges-tp4659059p4659062.html
- [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Sebastien Loriot (GeometryFactory), 04/03/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/12/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/13/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Sebastien Loriot (GeometryFactory), 04/14/2014
- Re: [cgal-discuss] Simplification: selection process and constrained edges, Zohar, 04/14/2014
