cgal-discuss - Re: [cgal-discuss] Difference between Manifold and Quasi-manifold
  • To:
  • Subject: Re: [cgal-discuss] Difference between Manifold and Quasi-manifold
  • Date: Wed, 11 Jun 2014 10:54:10 +0200
No. It is correctly a quasi-manifold of dimension 3. In fact, if you consider the star of p, then it satisfies the definition of QM. The star of p contains 4 pyramids, connected by common triangles. In fact, if you start from a pyramid, and navigate on common triangles you are able to visit all of them. Each triangle of pyramids in the star of p is shared by at most two pyramids. As a consequence, the star of p is manifold-connected. This is the definition of QM, if you read the article. In this case, the entire 3D shape is manifold-connected, but vertex p is non-manifold. Thus, classifying complexes is not a simple task, as you have understood.
Best regards
David
2014-06-11 8:42 GMT+02:00 Pranav <>:
In Figure 24.6(object on the right), opposite 3-cells are connected by a
vertex(or, a 0-cell) /p/ but still it is classified as quasi-manifold.
As per definition of quasi-manifold, a pair of d-cells can only be connected
by a shared (d-1)-cell.
Does that figure contradicts the definition of quasi-manifold?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Difference-between-Manifold-and-Quasi-manifold-tp4659420p4659424.html
