cgal-discuss - Re: [cgal-discuss] Removing edges and facets from a 3d triangulation
  • To:
  • Subject: Re: [cgal-discuss] Removing edges and facets from a 3d triangulation
  • Date: Tue, 24 Jun 2014 17:39:10 +0200
On 24/06/2014 17:32, Olivier Devillers wrote:
Le 6/24/14 5:18 PM, colonel_panic a écrit :
Hi,
I am looking for a way to remove cells, facets and edges from a 3d
triangulation using CGAL. There are functions provided to remove vertices
but I would like to keep all of the vertices and do not want to
retriangulate them.
It is possible to add a boolean flag in the cell base class to indicate
whether it should be removed but because edges and facets are not explicitly
or uniquely represented i am having difficulty finding a way to remove them
from the triangulation.
Is there a way to remove facets and edges from the triangulation?
I do not know why you wnat such an operation,
in the internal representation there are cells and vertices, so the edges (and facets)
are just the edges of the cells, you cannot remove edges without removing cells.
And removing cells is not a good idea since you no longer have a valid triangulation.
May be, you could be happy by "marking"the edges or facets as inactive.
While I have the same initial question (i.e. "why?"), could it be that you're not looking for a triangulation but a more general simplicial complex?
The triangulation is has the invariant that it is always a collection of tetrahedra. In other words: if a facet were to be removed, the cells that were incident to the facet would have to be replaced by new cells (and probably new facets).
