cgal-discuss - Re: [cgal-discuss] Removing edges and facets from a 3d triangulation
  • To:
  • Subject: Re: [cgal-discuss] Removing edges and facets from a 3d triangulation
  • Date: Tue, 24 Jun 2014 18:15:08 +0200
On 24/06/2014 18:02, colonel_panic wrote:
Thank you both for the replies. My algorithm is similar to that which
produced these results:
http://www.mage.fst.uha.fr/maillot/recherche/images/LDA.gif
I need to generate a delaunay triangulation from a point set to start with
and then refine it - the outcome could be a more general simplicial comple.
I would like to be able to remove facets though - an example of where this
would be useful would be reconstructing a shape from a point set which has
several holes or hollows. the 3d triangulation generates many cells which
go across the hollow and I would like to remove the cells which are in empty
space while keeping the ones which are on the surface of the shape.
I have thought about testing each facet and then printing each one which
meets the criteria to be included but this seems like a sluggish solution.
I was asking here first to see if there was an easier/more elegant way to do
it :)
If I understand your application correctly, you never need edges/facets that were not in the original triangulation.
In this case, it is probably best to mark the cells/facets/edges that you want to display. The connectivity of the cells should then not change, just the marks while you iterate. In other words, you don't remove any cells/facets/edges, you just choose whether to ignore them.
How you store these marks is up to you.
See http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__cell__base__with__info__3.html for a cell type that could store these marks if you can encode them in one value.
You could also implement your own cell_base subclass, but this does require significantly more effort. See also: http://doc.cgal.org/latest/Triangulation_3/index.html#title7
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Removing-edges-and-facets-from-a-3d-triangulation-tp4659472p4659475.html
