cgal-discuss - RE: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • To:
  • Subject: RE: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • Date: Thu, 3 Jul 2014 10:41:32 -0700 (PDT)
Dear Sebastien,
Thank you for your reply. I am using CGAL 4.4. The code is as follows:
#include <CGAL/Skin_surface_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/mesh_skin_surface_3.h>
#include <CGAL/Skin_surface_polyhedral_items_3.h>
#include <list>
#include <ESBTL/CGAL/EPIC_kernel_with_atom.h>
#include <ESBTL/default.h>
typedef ESBTL::CGAL::EPIC_kernel_with_atom                  K;
typedef ESBTL::CGAL::Default_system                         System;
typedef CGAL::Skin_surface_traits_3<K>                      Traits;
typedef CGAL::Skin_surface_3<Traits>                        Skin_surface_3;
typedef Skin_surface_3::FT                                  FT;
typedef Skin_surface_3::Weighted_point                      Weighted_point;
typedef Weighted_point::Point                               Bare_point;
typedef CGAL::Polyhedron_3<K>                               Polyhedron;
#include <list>
#include <fstream>
#include "skin_surface_writer.h"
#include "extract_balls_from_pdb.h"
int main(int argc, char *argv[]) {
  const char *filename;
  if (argc == 2) {
    filename = argv[1];
  } else {
    filename = "4lfq.pdb";
  std::list<Weighted_point> l;
  double                    shrinkfactor = 0.5;
  //Container for molecular system
  std::vector<System> systems;
  // Retrieve input balls:
  extract_balls_from_pdb<K>(filename,systems,std::back_inserter(l));
  // Construct skin surface:
  std::cout << "Constructing skin surface..." <<std::endl;
  Skin_surface_3 skin_surface(l.begin(), l.end(), shrinkfactor);
  // Extract mesh from the skin surface:
  std::cout << "Meshing skin surface..." <<std::endl;
  Polyhedron p;
  CGAL::mesh_skin_surface_3(skin_surface, p);
                std::cout << "Subdividing ..." << std::endl;
                CGAL::subdivide_skin_surface_mesh_3(skin_surface, p, 1);
  std::ofstream out("mesh.off");
  out << p;
  return 0;
From: Sebastien Loriot (GeometryFactory) [via cgal-discuss] [mailto:[hidden email]]
Sent: quinta-feira, 3 de julho de 2014 02:33
To: Rinaldo
Subject: Re: Use of ESBTL and Skin Surface create errors
On 07/02/2014 10:45 PM, Rinaldo wrote:
> I am having the same problem using the latest version for both ESBTL and
> CGAL.
> Do you know if the problem of using subdivide_skin_surface_mesh_3 with ESBTL
> has been fixed?
> Best wishes,
> Rinaldo
The fixes have been integrated into the release 4.2. What version of
CGAL are you using?
Do you have a small example showing the pb?
Sebastien.
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659514.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659516.html
To unsubscribe from Use of ESBTL and Skin Surface create errors, click here.
NAML
View this message in context: RE: Use of ESBTL and Skin Surface create errors
