cgal-discuss - Re: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • To:
  • Subject: Re: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • Date: Tue, 08 Jul 2014 07:24:50 +0200
On 07/07/2014 09:58 PM, Rinaldo wrote:
I am using OpenSUSE 13.1 amd its CGAL implementation.
What is the output of
> grep CGAL_VERSION /usr/include/CGAL/version.h ?
Cheers,
Rinaldo
*From:*Sebastien Loriot (GeometryFactory) [via cgal-discuss]
[ email] </user/SendEmail.jtp?type=node&node=4659533&i=0>]
*Sent:* sexta-feira, 4 de julho de 2014 03:47
*To:* Rinaldo
*Subject:* Re: Use of ESBTL and Skin Surface create errors
I just gave it a try and it worked here.
Could you give some details about your platform and what error you
encountered?
Sebastien.
On 07/03/2014 07:41 PM, Rinaldo wrote:
> Dear Sebastien,
> Thank you for your reply. I am using CGAL 4.4. The code is as follows:
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/Skin_surface_3.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/mesh_skin_surface_3.h>
> #include <CGAL/Skin_surface_polyhedral_items_3.h>
> #include <list>
> #include <ESBTL/CGAL/EPIC_kernel_with_atom.h>
> #include <ESBTL/default.h>
> typedef ESBTL::CGAL::EPIC_kernel_with_atom K;
> typedef ESBTL::CGAL::Default_system System;
> typedef CGAL::Skin_surface_traits_3<K> Traits;
> typedef CGAL::Skin_surface_3<Traits>
Skin_surface_3;
> typedef Skin_surface_3::FT FT;
> typedef Skin_surface_3::Weighted_point
Weighted_point;
> typedef Weighted_point::Point Bare_point;
> typedef CGAL::Polyhedron_3<K> Polyhedron;
> #include <list>
> #include <fstream>
> #include "skin_surface_writer.h"
> #include "extract_balls_from_pdb.h"
> int main(int argc, char *argv[]) {
> const char *filename;
> if (argc == 2) {
> filename = argv[1];
> } else {
> filename = "4lfq.pdb";
> std::list<Weighted_point> l;
> double shrinkfactor = 0.5;
> //Container for molecular system
> std::vector<System> systems;
> // Retrieve input balls:
> extract_balls_from_pdb<K>(filename,systems,std::back_inserter(l));
> // Construct skin surface:
> std::cout << "Constructing skin surface..." <<std::endl;
> Skin_surface_3 skin_surface(l.begin(), l.end(), shrinkfactor);
> // Extract mesh from the skin surface:
> std::cout << "Meshing skin surface..." <<std::endl;
> Polyhedron p;
> CGAL::mesh_skin_surface_3(skin_surface, p);
> std::cout << "Subdividing ..." << std::endl;
> CGAL::subdivide_skin_surface_mesh_3(skin_surface, p,
1);
> std::ofstream out("mesh.off");
> out << p;
> return 0;
> [ email] </user/SendEmail.jtp?type=node&node=4659518&i=0>]
> *Sent:* quinta-feira, 3 de julho de 2014 02:33
> *To:* Rinaldo
> On 07/02/2014 10:45 PM, Rinaldo wrote:
> > I am having the same problem using the latest version for both
ESBTL and
> > CGAL.
> > Do you know if the problem of using subdivide_skin_surface_mesh_3
> with ESBTL
> > has been fixed?
> > Best wishes,
> > Rinaldo
> The fixes have been integrated into the release 4.2. What version of
> CGAL are you using?
> Do you have a small example showing the pb?
> Sebastien.
> > View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659514.html
> > Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> *If you reply to this email, your message will be added to the
> discussion below:*
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659516.html
> To unsubscribe from Use of ESBTL and Skin Surface create errors,
click here.
> NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: RE: Use of ESBTL and Skin Surface create
> errors
<http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659518.html>
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
discussion below:*
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659521.html
To unsubscribe from Use of ESBTL and Skin Surface create errors, click here.
NAML
errors
<http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659533.html>
