cgal-discuss - RE: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • To:
  • Subject: RE: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • Date: Mon, 7 Jul 2014 12:58:20 -0700 (PDT)
I am using OpenSUSE 13.1 amd its CGAL implementation.
Cheers,
Rinaldo
From: Sebastien Loriot (GeometryFactory) [via cgal-discuss] [mailto:[hidden email]]
Sent: sexta-feira, 4 de julho de 2014 03:47
To: Rinaldo
Subject: Re: Use of ESBTL and Skin Surface create errors
I just gave it a try and it worked here.
Could you give some details about your platform and what error you
encountered?
Sebastien.
On 07/03/2014 07:41 PM, Rinaldo wrote:
> Dear Sebastien,
> Thank you for your reply. I am using CGAL 4.4. The code is as follows:
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/Skin_surface_3.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/mesh_skin_surface_3.h>
> #include <CGAL/Skin_surface_polyhedral_items_3.h>
> #include <list>
> #include <ESBTL/CGAL/EPIC_kernel_with_atom.h>
> #include <ESBTL/default.h>
> typedef ESBTL::CGAL::EPIC_kernel_with_atom                  K;
> typedef ESBTL::CGAL::Default_system                         System;
> typedef CGAL::Skin_surface_traits_3<K>                      Traits;
> typedef CGAL::Skin_surface_3<Traits>                        Skin_surface_3;
> typedef Skin_surface_3::FT                                  FT;
> typedef Skin_surface_3::Weighted_point                      Weighted_point;
> typedef Weighted_point::Point                               Bare_point;
> typedef CGAL::Polyhedron_3<K>                               Polyhedron;
> #include <list>
> #include <fstream>
> #include "skin_surface_writer.h"
> #include "extract_balls_from_pdb.h"
> int main(int argc, char *argv[]) {
>    const char *filename;
>    if (argc == 2) {
>      filename = argv[1];
>    } else {
>      filename = "4lfq.pdb";
>    std::list<Weighted_point> l;
>    double                    shrinkfactor = 0.5;
>    //Container for molecular system
>    std::vector<System> systems;
>    // Retrieve input balls:
>    extract_balls_from_pdb<K>(filename,systems,std::back_inserter(l));
>    // Construct skin surface:
>    std::cout << "Constructing skin surface..." <<std::endl;
>    Skin_surface_3 skin_surface(l.begin(), l.end(), shrinkfactor);
>    // Extract mesh from the skin surface:
>    std::cout << "Meshing skin surface..." <<std::endl;
>    Polyhedron p;
>    CGAL::mesh_skin_surface_3(skin_surface, p);
>                  std::cout << "Subdividing ..." << std::endl;
>                  CGAL::subdivide_skin_surface_mesh_3(skin_surface, p, 1);
>    std::ofstream out("mesh.off");
>    out << p;
>    return 0;
> *From:*Sebastien Loriot (GeometryFactory) [via cgal-discuss]
> [mailto:[hidden email] </user/SendEmail.jtp?type=node&node=4659518&i=0>]
> *Sent:* quinta-feira, 3 de julho de 2014 02:33
> *To:* Rinaldo
> *Subject:* Re: Use of ESBTL and Skin Surface create errors
> On 07/02/2014 10:45 PM, Rinaldo wrote:
>  > I am having the same problem using the latest version for both ESBTL and
>  > CGAL.
>  > Do you know if the problem of using subdivide_skin_surface_mesh_3
> with ESBTL
>  > has been fixed?
>  > Best wishes,
>  > Rinaldo
> The fixes have been integrated into the release 4.2. What version of
> CGAL are you using?
> Do you have a small example showing the pb?
> Sebastien.
>  > View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659514.html
>  > Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> *If you reply to this email, your message will be added to the
> discussion below:*
> http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659516.html
> To unsubscribe from Use of ESBTL and Skin Surface create errors, click here.
> NAML
> <http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: RE: Use of ESBTL and Skin Surface create
> errors
> <http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659518.html>
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653p4659521.html
NAML
View this message in context: RE: Use of ESBTL and Skin Surface create errors
