cgal-discuss - Re: [cgal-discuss] Convex decomposition of concave mesh
  • To:
  • Subject: Re: [cgal-discuss] Convex decomposition of concave mesh
  • Date: Thu, 11 Sep 2014 20:56:23 +0200
Some additional info, sorry for the 2nd email:
POL.is_pure_triangle = 1 -> that means that luckily I don't have degenerate triangles.
Also, step 3 (CGAL::convex_decomposition_3( NEF ))  finished after much time (~1 hour?) and returned 25642 convex parts,
while the original OFF file (attached) has 20000 triangles (problem correlated with what I reported about 2x the number of vertices).
OFF
10002 20000 0
59.297 -0.455242 -70.6708
66.3921 -1.96008 -58.9775
OFF
10002 20000 0
On Thu, Sep 11, 2014 at 8:09 PM, Dimitris Tzionas <> wrote:
Hi all,
In a physics simulation I have a problem with concave meshes, so it seems that I really have to do decomposition in convex mesh-parts.
Since CGAL covered successfully past needs, I was hoping to use this again.
It seems that it is doable only by using Nef_polyhedron_3.
In order to have this representation:
- I first read a .off file (ideally this should happen from memory, but my code is slower than CGAL's built-in reader from file) in a Polyhedron_3. My mesh is closed and depicted fine with the Polyhedron viewer demo.
- then I convert to a Nef_polyhedron_3.
- Finally I try to use CGAL::convex_decomposition_3
- The first part is very fast.
std::ifstream file("/home/dimitris/Model_Hand_R.off");
file >> POL;
However instead of 10002 vertices I noticed that I get
POL.size_of_vertices = 20004
POL.is_closed = 1
- The second part takes ~15sec for 20k vertices.
Nef_polyhedron_3 NEF( POL );
NEF.is_empty: 0
Nef vertices: 20004
Nef edges: 60000
Nef facets: 40000
Nef volumes: 3
The third part takes forever and never returns anything.
CGAL::convex_decomposition_3( NEF );
Could it be that I'm doing something very obviously wrong?
Could I get best practices hints for this problem?
What is a sensible run-time for CGAL's approach?
Some extra info on the current setup:
typedef CGAL::Exact_predicates_exact_constructions_kernel       Kernel;
typedef CGAL::Polyhedron_3<Kernel>                              Polyhedron;
typedef CGAL::Nef_polyhedron_3<Kernel, CGAL::SNC_indexed_items> Nef_polyhedron_3;
Thank you in advance for potential hints,
Dimitris
Attachment: Model_Hand_R.off.zip
Description: Zip archive
