cgal-discuss - Re: [cgal-discuss] Convex decomposition of concave mesh
  • To:
  • Subject: Re: [cgal-discuss] Convex decomposition of concave mesh
  • Date: Fri, 12 Sep 2014 10:59:07 +0200
Hi Sebastien,
The double number of vertices was because of a non commented-out code snippet that was doing the same thing twice (converting into Polygon representation the same mesh, both from memory and the .off file).
My fault.
However, the most important thing I saw after experiments is exactly what you say.
It seems that the convex decomposition that CGAL does is an exact one (no approximations).
Meshes that are the result of scanning real-life surfaces will have a somewhat noisy surface and this will result in a large number convex sub-parts, that is too big for practical scenarios.
So, I totally agree with what you say.
For the record, this is the output for the mesh that I attached:
POL.size_of_vertices = 10002
POL.size_of_facets = 20000
POL.is_closed = 1
POL.is_pure_triangle = 1
NEF.is_empty: 0
Nef vertices: 10002
Nef edges: 30000
Nef facets: 20000
Nef volumes: 2
Nef is_simple: 1
decomposition into 12780 convex parts
The decomposition took more than 30 minutes (I don't have exact timing), but probably this was exactly because of the noisy mesh,
and thus (probably) because of added workload. Hopefully with clean meshes one can get much better timings.
Thanks for the valuable feedback!
Dimitris
On Fri, Sep 12, 2014 at 10:05 AM, Sebastien Loriot (GeometryFactory) <> wrote:
I loaded the model in the polyhedron demo, converted it into nef and I got 10002 vertices.
Then I ran the convex decomposition which indeed took some time but
provided a convex decomposition that is valid but obviously not the
minimal one.
The kind of model the algorithm was written for is more for mechanical
parts rather than "noisy" or smooth surfaces.
IMO, it should not be used in such cases.
Sebastien.
On 09/11/2014 08:56 PM, Dimitris Tzionas wrote:
Some additional info, sorry for the 2nd email:
POL.is_pure_triangle = 1 -> that means that luckily I don't have
degenerate triangles.
Also, step 3 (CGAL::convex_decomposition_3(NEF))  finished after much
time (~1 hour?) and returned 25642 convex parts,
while the original OFF file (attached) has 20000 triangles (problem
correlated with what I reported about 2x the number of vertices).
OFF
10002 20000 0
59.297 -0.455242 -70.6708
66.3921 -1.96008 -58.9775
On Thu, Sep 11, 2014 at 8:54 PM, Dimitris Tzionas <
    much time (~1 hour?) and returned 25642 convex parts,
    OFF
    10002 20000 0
    On Thu, Sep 11, 2014 at 8:09 PM, Dimitris Tzionas
    < <mailto:>> wrote:
        Hi all,
        In a physics simulation I have a problem with concave meshes, so
        it seems that I really have to do decomposition in convex
        mesh-parts.
        Since CGAL covered successfully past needs, I was hoping to use
        this again.
        It seems that it is doable only by using Nef_polyhedron_3.
        http://doc.cgal.org/latest/Convex_decomposition_3/index.html
        In order to have this representation:
        - I first read a .off file (ideally this should happen from
        memory, but my code is slower than CGAL's built-in reader from
        file) in a Polyhedron_3. My mesh is closed and depicted fine
        with the Polyhedron viewer demo.
        - then I convert to a Nef_polyhedron_3.
        - Finally I try to use CGAL::convex_decomposition_3
        - The first part is very fast.
        std::ifstream  file("/home/dimitris/Model_Hand_R.off");
        file  >>  POL;
        However instead of 10002 vertices I noticed that I get
        POL.size_of_vertices = 20004
        POL.is_closed = 1
        - The second part takes ~15sec for 20k vertices.
        Nef_polyhedron_3  NEF(  POL  );
        NEF.is_empty: 0
        Nef vertices: 20004
        Nef edges: 60000
        Nef facets: 40000
        Nef volumes: 3
        - The third part takes forever and never returns anything.
        CGAL::convex_decomposition_3(  NEF  );
        Could it be that I'm doing something very obviously wrong?
        Could I get best practices hints for this problem?
        What is a sensible run-time for CGAL's approach?
        Some extra info on the current setup:
        typedef  CGAL::Exact_predicates_exact_constructions_kernel        Kernel;
        typedef  CGAL::Polyhedron_3<Kernel>                               Polyhedron;
        typedef  CGAL::Nef_polyhedron_3<Kernel,  CGAL::SNC_indexed_items>  Nef_polyhedron_3;
        Thank you in advance for potential hints,
        Dimitris
