cgal-discuss - Re: [cgal-discuss] Convex decomposition of concave mesh
  • To:
  • Subject: Re: [cgal-discuss] Convex decomposition of concave mesh
  • Date: Fri, 12 Sep 2014 11:04:39 +0200
Hi Dimitris,
What would you like to compute? Wouldn't the segmentation
http://doc.cgal.org/latest/Manual/packages.html#PkgSurfaceSegmentationSummary
be a solution? You might cut the surface and fill the holes
to make each part a closed surface again.
andreas
On 12/09/2014 10:59, Dimitris Tzionas wrote:
Hi Sebastien,
The double number of vertices was because of a non commented-out code
snippet that was doing the same thing twice (converting into Polygon
representation the same mesh, both from memory and the .off file).
My fault.
However, the most important thing I saw after experiments is exactly
what you say.
It seems that the convex decomposition that CGAL does is an exact one
(no approximations).
Meshes that are the result of scanning real-life surfaces will have a
somewhat noisy surface and this will result in a large number convex
sub-parts, that is too big for practical scenarios.
So, I totally agree with what you say.
For the record, this is the output for the mesh that I attached:
POL.size_of_vertices = 10002
POL.size_of_facets = 20000
POL.is_closed = 1
POL.is_pure_triangle = 1
NEF.is_empty: 0
Nef vertices: 10002
Nef edges: 30000
Nef facets: 20000
Nef volumes: 2
Nef is_simple: 1
decomposition into 12780 convex parts
The decomposition took more than 30 minutes (I don't have exact timing),
but probably this was exactly because of the noisy mesh,
and thus (probably) because of added workload. Hopefully with clean
meshes one can get much better timings.
Thanks for the valuable feedback!
Dimitris
On Fri, Sep 12, 2014 at 10:05 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
I loaded the model in the polyhedron demo, converted it into nef and
I got 10002 vertices.
Then I ran the convex decomposition which indeed took some time but
provided a convex decomposition that is valid but obviously not the
minimal one.
The kind of model the algorithm was written for is more for mechanical
parts rather than "noisy" or smooth surfaces.
IMO, it should not be used in such cases.
Sebastien.
On 09/11/2014 08:56 PM, Dimitris Tzionas wrote:
Some additional info, sorry for the 2nd email:
POL.is_pure_triangle = 1 -> that means that luckily I don't have
degenerate triangles.
Also, step 3 (CGAL::convex_decomposition_3(__NEF)) finished
after much
time (~1 hour?) and returned 25642 convex parts,
while the original OFF file (attached) has 20000 triangles (problem
correlated with what I reported about 2x the number of vertices).
OFF
10002 20000 0
59.297 -0.455242 -70.6708
66.3921 -1.96008 -58.9775
On Thu, Sep 11, 2014 at 8:54 PM, Dimitris Tzionas
<mailto:>
<mailto:
<mailto:>>__>
have
finished after
much time (~1 hour?) and returned 25642 convex parts,
(problem
vertices).
OFF
10002 20000 0
On Thu, Sep 11, 2014 at 8:09 PM, Dimitris Tzionas
<mailto:>
<mailto:
<mailto:>>__>
wrote:
Hi all,
In a physics simulation I have a problem with concave
meshes, so
it seems that I really have to do decomposition in convex
mesh-parts.
Since CGAL covered successfully past needs, I was
hoping to use
this again.
It seems that it is doable only by using Nef_polyhedron_3.
http://doc.cgal.org/latest/__Convex_decomposition_3/index.__html
<http://doc.cgal.org/latest/Convex_decomposition_3/index.html>
In order to have this representation:
- I first read a .off file (ideally this should happen from
memory, but my code is slower than CGAL's built-in
reader from
file) in a Polyhedron_3. My mesh is closed and depicted
fine
with the Polyhedron viewer demo.
- then I convert to a Nef_polyhedron_3.
- Finally I try to use CGAL::convex_decomposition_3
- The first part is very fast.
std::ifstream file("/home/dimitris/Model___Hand_R.off");
file >> POL;
However instead of 10002 vertices I noticed that I get
POL.size_of_vertices = 20004
POL.is_closed = 1
- The second part takes ~15sec for 20k vertices.
Nef_polyhedron_3 NEF( POL );
NEF.is_empty: 0
Nef vertices: 20004
Nef edges: 60000
Nef facets: 40000
Nef volumes: 3
- The third part takes forever and never returns anything.
CGAL::convex_decomposition_3( NEF );
Could it be that I'm doing something very obviously wrong?
Could I get best practices hints for this problem?
What is a sensible run-time for CGAL's approach?
Some extra info on the current setup:
typedef
CGAL::Exact_predicates_exact___constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel>
Polyhedron;
typedef CGAL::Nef_polyhedron_3<Kernel,
CGAL::SNC_indexed_items> Nef_polyhedron_3;
Thank you in advance for potential hints,
Dimitris
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
