cgal-discuss - Re: [cgal-discuss] Delaunay_d not making triangulation
  • To:
  • Subject: Re: [cgal-discuss] Delaunay_d not making triangulation
  • Date: Tue, 14 Oct 2014 17:02:42 -0700
I should add that my test results are:
┌─[adam][Hapkido][±][master ][~/CDT-plusplus]
└─▪ ./build/unittests
[==========] Running 3 tests from 3 test cases.
[----------] Global test environment set-up.
[----------] 1 test from S3Triangulation
[ RUN      ] S3Triangulation.CreatesTetrahedronTriangulation
[       OK ] S3Triangulation.CreatesTetrahedronTriangulation (0 ms)
[----------] 1 test from S3Triangulation (0 ms total)
[----------] 1 test from SdTriangulation
[ RUN      ] SdTriangulation.CreateTetrahedralTriangulationIn4D
/Users/adam/CDT-plusplus/unittests/SdTriangulationTest.cpp:17: Failure
Value of: T.number_of_vertices()
Expected: is equal to 4
  Actual: 2 (of type unsigned long)
Triangulation has wrong number of vertices.
[  FAILED  ] SdTriangulation.CreateTetrahedralTriangulationIn4D (2 ms)
[----------] 1 test from SdTriangulation (2 ms total)
[----------] 1 test from Sphere
[ RUN      ] Sphere.CreatesSphere
Generating 5 random points on the surface of a sphere in 4D
of center 0 and radius 1.
 4 -0.662836 -0.599316 -0.433747 0.115464
 4 0.475419 -0.310349 -0.696182 0.439306
 4 -0.206109 0.270425 -0.180448 -0.922945
 4 -0.716342 -0.652304 -0.239908 0.0616242
 4 -0.25399 0.651968 -0.504896 -0.505476
[       OK ] Sphere.CreatesSphere (1 ms)
[----------] 1 test from Sphere (1 ms total)
[----------] Global test environment tear-down
[==========] 3 tests from 3 test cases ran. (4 ms total)
[  PASSED  ] 2 tests.
[  FAILED  ] 1 test, listed below:
 1 FAILED TEST
  YOU HAVE 1 DISABLED TEST
On Tue, Oct 14, 2014 at 5:00 PM, Adam Getchell <> wrote:
Hello all,
I can successfully make a tetrahedral triangulation with a Triangulation_3:
But not with a Delaunay_d:
In particular, it only generates 2 vertices, even in the DISABLED test case that inserts 8.
Suggestions?
Thanks,
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
Adam Getchell
