cgal-discuss - Re: [cgal-discuss] Delaunay_d not making triangulation
  • To:
  • Subject: Re: [cgal-discuss] Delaunay_d not making triangulation
  • Date: Thu, 16 Oct 2014 00:38:33 -0700
Hi Marc,
Thanks for the suggestion. I wrote a function to iterate on the vertices and counted them, and I still only ever get two, for both my test cases where I insert 4 for a tetrahedron and 8 for a 16cell:
https://github.com/acgetchell/CDT-plusplus/blob/master/src/Delaunay.h
https://github.com/acgetchell/CDT-plusplus/blob/master/unittests/SdTriangulationTest.cpp
With these results:
┌─[adam][Hapkido][±][master ][~/CDT-plusplus]
└─▪ ./build/unittests
[==========] Running 4 tests from 3 test cases.
[----------] Global test environment set-up.
[----------] 1 test from S3Triangulation
[ RUN      ] S3Triangulation.CreatesTetrahedronTriangulation
[       OK ] S3Triangulation.CreatesTetrahedronTriangulation (1 ms)
[----------] 1 test from S3Triangulation (1 ms total)
[----------] 2 tests from SdTriangulation
[ RUN      ] SdTriangulation.CreatesTetrahedralTriangulationIn4D
Point #1
Point #2
/Users/adam/CDT-plusplus/unittests/SdTriangulationTest.cpp:32: Failure
Value of: CountVertices(&T)
Expected: is equal to 4
  Actual: 2 (of type int)
Triangulation has wrong number of vertices.
[  FAILED  ] SdTriangulation.CreatesTetrahedralTriangulationIn4D (0 ms)
[ RUN      ] SdTriangulation.Creates16cellTriangulationIn4D
Point #1
Point #2
/Users/adam/CDT-plusplus/unittests/SdTriangulationTest.cpp:58: Failure
Expected: is equal to 8
[  FAILED  ] SdTriangulation.Creates16cellTriangulationIn4D (0 ms)
[----------] 2 tests from SdTriangulation (0 ms total)
[----------] 1 test from Sphere
[ RUN      ] Sphere.CreatesSphere
Generating 5 random points on the surface of a sphere in 4D
of center 0 and radius 1.
 4 -0.3052 0.52678 -0.541574 -0.579702
 4 0.506331 0.715467 -0.419326 0.236436
 4 -0.245088 -0.622645 -0.544896 -0.505305
 4 0.960938 -0.18142 -0.155713 -0.139425
 4 -0.46617 -0.27773 -0.583959 0.603775
[       OK ] Sphere.CreatesSphere (0 ms)
[----------] 1 test from Sphere (0 ms total)
[----------] Global test environment tear-down
[==========] 4 tests from 3 test cases ran. (2 ms total)
[  PASSED  ] 2 tests.
[  FAILED  ] 2 tests, listed below:
 2 FAILED TESTS
On Tue, Oct 14, 2014 at 10:34 PM, Marc Glisse <> wrote:
On Tue, 14 Oct 2014, Adam Getchell wrote:
I can successfully make a tetrahedral triangulation with a Triangulation_3:
https://github.com/acgetchell/CDT-plusplus/blob/master/unittests/S3TriangulationTest.cpp
But not with a Delaunay_d:
In particular, it only generates 2 vertices, even in the DISABLED test case
that inserts 8.
Hello,
is the function number_of_vertices the only one giving you trouble? Did you try iterating on the vertices and counting them? I have a vague memory of a function, maybe this one, not working correctly, but not affecting the rest either.
Marc Glisse
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
