- To:
- Subject: Re: [cgal-discuss] Delaunay_d not making triangulation
- Date: Thu, 16 Oct 2014 07:08:05 -0700
┌─[adam][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ ./build/unittests
[==========] Running 4 tests from 3 test cases.
[----------] Global test environment set-up.
[----------] 1 test from S3Triangulation
[ RUN ] S3Triangulation.CreatesTetrahedronTriangulation
[ OK ] S3Triangulation.CreatesTetrahedronTriangulation (0 ms)
[----------] 1 test from S3Triangulation (0 ms total)
[----------] 2 tests from SdTriangulation
[ RUN ] SdTriangulation.CreatesTetrahedralTriangulationIn4D
Point #1
Point #2
Point #3
Point #4
/Users/adam/CDT-plusplus/unittests/SdTriangulationTest.cpp:36: Failure
Value of: T.is_valid()
Actual: false
Expected: true
Triangulation is invalid.
[ FAILED ] SdTriangulation.CreatesTetrahedralTriangulationIn4D (0 ms)
[ RUN ] SdTriangulation.Creates16cellTriangulationIn4D
Point #1
Point #2
Point #3
Point #4
Point #5
/Users/adam/CDT-plusplus/unittests/SdTriangulationTest.cpp:58: Failure
Value of: CountVertices(&T)
Expected: is equal to 8
Actual: 5 (of type int)
Triangulation has wrong number of vertices.
[ FAILED ] SdTriangulation.Creates16cellTriangulationIn4D (1 ms)
[----------] 2 tests from SdTriangulation (1 ms total)
[----------] 1 test from Sphere
[ RUN ] Sphere.CreatesSphere
Generating 5 random points on the surface of a sphere in 4D
of center 0 and radius 1.
4 0.216594 0.895128 -0.251742 0.29742
4 0.108702 -0.14668 -0.405465 -0.895694
4 -0.170433 0.0644393 -0.980995 0.0666965
4 0.453997 0.691497 -0.358078 0.433012
4 0.91417 -0.310213 0.210919 -0.153542
[ OK ] Sphere.CreatesSphere (0 ms)
[----------] 1 test from Sphere (0 ms total)
[----------] Global test environment tear-down
[==========] 4 tests from 3 test cases ran. (1 ms total)
[ PASSED ] 2 tests.
[ FAILED ] 2 tests, listed below:
2 FAILED TESTS
On Thu, 16 Oct 2014, Adam Getchell wrote:
Hi Marc,
Thanks for the suggestion. I wrote a function to iterate on the vertices and counted them, and I still only ever get two, for both my test cases where I insert 4 for a
tetrahedron and 8 for a 16cell:
https://github.com/acgetchell/CDT-plusplus/blob/master/src/Delaunay.h
https://github.com/acgetchell/CDT-plusplus/blob/master/unittests/SdTriangulationTest.cpp
Point(0,0,0,0)
are you expecting this to be the origin in R^4? Since you are using a Homogeneous kernel, I would expect it to be a point in R^3, of coordinates (0./0.,0./0.,0./0.). And indeed in debug mode (which you should be using when writing new code) I am getting:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: (w!=0)
File: /usr/include/CGAL/Kernel_d/PointHd.h
Line: 162
Explanation: PointHd::construction: w == 0.
Marc Glisse
- [cgal-discuss] Delaunay_d not making triangulation, Adam Getchell, 10/15/2014
- Re: [cgal-discuss] Delaunay_d not making triangulation, Adam Getchell, 10/15/2014
- Re: [cgal-discuss] Delaunay_d not making triangulation, Marc Glisse, 10/15/2014
- Re: [cgal-discuss] Delaunay_d not making triangulation, Adam Getchell, 10/16/2014
- Re: [cgal-discuss] Delaunay_d not making triangulation, Marc Glisse, 10/16/2014
- Re: [cgal-discuss] Delaunay_d not making triangulation, Adam Getchell, 10/23/2014
