cgal-discuss - Re: [cgal-discuss] Delaunay_d not making triangulation
  • To:
  • Subject: Re: [cgal-discuss] Delaunay_d not making triangulation
  • Date: Thu, 23 Oct 2014 00:14:05 -0700
Marc,
Thank you, using an InputIterator to build my points up was the key idea I
learned.
> On Oct 16, 2014, at 7:27 AM, Marc Glisse
> wrote:
> On Thu, 16 Oct 2014, Adam Getchell wrote:
>> Marc,
>> Thanks again for your comments.
>> I wondered if it were due to using the Homogenous kernel. If I change to a
>> Cartesian kernel, then the first test fails due to invalid triangulation,
>> and the second test still yields only 5 vertices instead of 8. I looked at
>> the cartesian to homogenous point converters, but they only go to three
>> dimensions. Suggestions?
> Ah, it still interprets them as homogeneous coordinates, that sucks... You
> need to build your points using iterators. For instance:
> int arr[]={0,0,0,0};
> Point p(4,arr,arr+4);
> It works just as well with Cartesian or homogeneous. If the distance
> between the iterators is larger than the dimension passed as first
> argument, it will divide everything by that last value.
>> (Also, how do you switch to debug mode?)
> That's a property of your build system, you are supposed to know and I have
> absolutely no idea.
> Marc Glisse
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
