Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- To:
- Subject: Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- Date: Fri, 07 Nov 2014 09:52:27 +0100
A way to do it is to use the AABB-tree on the facets of the original model and call AABB_tree::closest_point_and_primitive using the point
of each vertex in the remeshed surface.
See http://doc.cgal.org/latest/AABB_tree/index.html
Sebastien.
On 11/05/2014 04:10 AM, hmzhangmin wrote:
Hi My friends,
When generate mesh for a 3D surface, we can get a triangle mesh which is
stored in "SurfaceMeshComplex_2InTriangulation_3" object, this is
implemented in function "make_surface_mesh".
Ok, now we know the coordinates of every vertex in the triangle mesh, but we
don't know the u/v
parameter of the vertex in the original surface. As we know, after mesh
generation, every vertex in the result triangle mesh lie on the original
surface.
So, my question is: how can we get the u/v parameter pair for vertex in
triangle mesh after mesh generation of a 3D surface?
Thanks you very much.
Min
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/an-issue-about-the-u-v-parameter-for-vertex-after-mesh-generation-for-surface-tp4660049.html
- [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/05/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/07/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, Sebastien Loriot (GeometryFactory), 11/07/2014
