Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- To:
- Subject: Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- Date: Fri, 07 Nov 2014 10:38:55 +0100
On 11/07/2014 10:16 AM, hmzhangmin wrote:
Hi Sebastien,
Thanks very much for your reply.
I have read the document just now.
In my understanding, we can construct an AABB tree for the mesh which we
generated for a 3D surface, then we can call
AABB_tree::closest_point_and_primitive which takes the point of each vertex
as input. Now we get a Point_and_primitive_id object, the returned point
will have the same coordinates with the input point, because all the vertex
in a triangle mesh lies on the original 3D surface.
Also a primitive ID is returned, from this ID we know the facet which just
contains the input vertex.
So, we still don't know the u/v parameter of each vertex in the original
surface.
Maybe I don't get what you mean by u/v. I though it was the parametric coordinates on the original surface (given a parametrization of the original surface). If you have a points on the original surface then you get the u/v.
Sebastien.
In OpenCascade, we can call a function to generate triangle mesh for a 3D
surface, the result contains an array which stores coordinates for all
vertexes, it also contains an array which stores all the u/v parameter pair
for all vertexes.
I'm not sure whether my understanding is right or not, please correct it
Thanks very much,
Min
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/an-issue-about-the-u-v-parameter-for-vertex-after-mesh-generation-for-surface-tp4660049p4660072.html
- [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/05/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/07/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, Sebastien Loriot (GeometryFactory), 11/07/2014
