[cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- To:
- Subject: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- Date: Tue, 4 Nov 2014 19:10:51 -0800 (PST)
Hi My friends,
When generate mesh for a 3D surface, we can get a triangle mesh which is
stored in "SurfaceMeshComplex_2InTriangulation_3" object, this is
implemented in function "make_surface_mesh".
Ok, now we know the coordinates of every vertex in the triangle mesh, but we
don't know the u/v
parameter of the vertex in the original surface. As we know, after mesh
generation, every vertex in the result triangle mesh lie on the original
surface.
So, my question is: how can we get the u/v parameter pair for vertex in
triangle mesh after mesh generation of a 3D surface?
Thanks you very much.
Min
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/an-issue-about-the-u-v-parameter-for-vertex-after-mesh-generation-for-surface-tp4660049.html
- [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/05/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/07/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, Sebastien Loriot (GeometryFactory), 11/07/2014
