cgal-discuss - Re: [cgal-discuss] Epick convex_hull_3 assertion
  • To:
  • Subject: Re: [cgal-discuss] Epick convex_hull_3 assertion
  • Date: Mon, 05 Jan 2015 19:15:13 +0100
On 01/04/2015 06:36 PM, Marius Kintel wrote:
On Jan 4, 2015, at 05:56 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Marc is right. Could you try with the following patched file?
With the patched file, it no longer throws an exception.
However, it also doesn’t correctly calculate the hull.
See screenshot of my polyhedron before and after hull.
If necessary I can try to slim this down to a minimal test case.
In case, do you have a small demo/example program which I could modify
to output something useful?
Cheers,
Mmm, the input does not look 2D.
Do you have the off of the input?
Thanks,
Sebastien.
-Marius
