- To:
- Subject: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
- Date: Sun, 29 Nov 2015 22:25:29 -0800 (PST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:/nLqmRMsGDlL2jyu5Vgl6mtUPXoX/o7sNwtQ0KIMzox0KPr4rarrMEGX3/hxlliBBdydsKIZzbqI+Pq9BCQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTqkbDssMeOPk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv/hpCvurOv1gBfwDVGxnYCgJ45jguhDHCAeO/XABSX4+kxxSAgGD4gupcI32t37rsexywymXO8KnEfhgRT2k/qBtRwTohSEIb25hrUnYj8VxiORQpxf39E83+JLdfIzAbak2RajaZ95PHjIZUw==
Hi guys, i'm trying to run Polyhedron demo but it was not successful. I was
able to run cmake and make successfully, but fail when trying to run the
Unix Executable. I configured Qt 5 and libQGLViewer, it even showed those
libs have been found, but i have no why the executable failed to run. The
log is at below:
*dyld: Library not loaded: QGLViewer.framework/Versions/2/QGLViewer
Referenced from:
/Users/tanyongsheng/Desktop/CGAL-4.7/demo/Polyhedron/./polyhedron_3
Reason: image not found
Trace/BPT trap: 5*
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Fail-to-run-Polyhedron-demo-with-reason-Image-not-found-tp4661416.html
- [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', yongsheng94, 11/30/2015
- Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', yongsheng94, 11/30/2015
- Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', Sebastien Loriot (GeometryFactory), 11/30/2015
